It is currently Sun Feb 08, 2026 11:44 am
Post a new topicPost a reply Page 1 of 3   [ 36 posts ]
Go to page 1, 2, 3  Next
 Post subject: 1982 242 turbo, aka Athals car
PostPosted: Sat Apr 04, 2009 4:55 pm
Yup, the time has come to start the process.
I can post some pictures if you like, most of you have seen it plenty already. I'll be keeping the 16 Darth, but have no need for keeping 2 sets (plus winters).
NOT parting out the motor at this point
§ Alpine tape deck with 6 disc changer ($100), Denon eq w sub control ($50), 2 amps (cheap but decent pioneer to rear ($40), Rockford fosgate punch 40 ($75) to sub), 10” boxed sub ($50)
~30,000km on engine ($750 complete)
§ B23E block, new B23ET (9:1) forged pistons, forged rods, crank
§ Gently ported and polished 405 head, new valves, 3 angle grind
o First generation valve springs (stiffer than newer style)
o Custom camshaft (CK1, K-exhaust lobe, ~A intake)
o Avalanche cam gear
§ Approximately 9.2:1 CR, low boost (~7psi) on 87 octane
§ B23E intake manifold
§ 90+ ported exhaust manifold
§ Garrett T3 turbo 0.63 AR turbine, 0.42AR 60 trim compressor
§ 205whp/220wtrq at 12psi (with larger turbo), VERY drivable, decent economy
§ 3” turbo back mandrel bent exhaust, magnaflow cat, straight thru muffler, stainless tip ($200)
§ large NPR intercooler ($150)
§ k&n cone filter ($30)
SOLD balanced and cleaned 357 (stock) injectors
§ LH2.2 fuel chip ($100)
Suspension
SOLD Rear Koni yellow sport adjustable ~10,000km
§ IPD 25/25 anti sway bars ($150)
SOLD IPD adjustable torque rods
§ IPD adjustable panhard rod ($60)
§ GT upper chassis/strut braces ($30)
Wheels and Tires
§ 17x7” Allesio “turbo” wheels ($500)
o minor rash
o 215/45/17 bridgestone re92, only 2 seasons on them
o 37mm front wheel drive offset
SOLD 10mm front and 25mm rear Avalanche wheel spacers/adapters.
Last edited by swedishmeatball on Tue Dec 15, 2009 2:23 pm, edited 2 times in total.
 Post subject: Re: 1982 242 turbo, aka Athals car
PostPosted: Sat Apr 04, 2009 6:30 pm
Oh man....
I'm sad to see this car go Athal, but I completely understand your reasons for doing it.
Good luck with the sale. If the time comes to part it out, there will be a few things I'd like, namely the LSD, panhard and torque rods. I'd REALLY like that engine in the YROG, but doubt I could swing it right now. Oh man, that would be sick if I could.
Keep us posted.
PostPosted: Sat Apr 04, 2009 9:11 pm
Id be interested in those sways for sure, likely the shocks and springs as well.
PostPosted: Sun Apr 12, 2009 9:03 am
posted on tbricks this morning. guess i'll do craigslist and kijiji too. give it another week or so then i'll look at parting...
PostPosted: Mon May 25, 2009 2:09 pm
BUMP.
If I can't sell most of this stuff to you guys, I'm not going to bother parting it out. I may just find a decent '86+ 244 to swap it all into and then use that as my winter driver or sell it complete.
So, let me know if you want parts, reply in the thread so I don't have to sort through pms please!
PostPosted: Mon May 25, 2009 3:23 pm
Wasn't someone selling their white '90+ 245 on here?
PostPosted: Mon May 25, 2009 3:41 pm
could probably use rear 25mm spacers and KG2T maybe :D
PostPosted: Mon May 25, 2009 4:18 pm
I'll likely take the diff. Just need to consult with significant other.
Will post here shortly about anything else. That engine is sounding more tempting, considering I just found out I have 40% leakdown on cyl. #2 in YROG.
PostPosted: Mon May 25, 2009 5:12 pm
40%? Pfft, im running the saab with 60% in cyl 2...I gotta get around to that headgasket...
I'll check with Dave and see if we need anything
PostPosted: Mon May 25, 2009 8:28 pm
I'll look again Matt, I do remember but it seemed like to nice of a candidate perhaps, and I was hoping to score a broken car for under a grand kinda thing. A wagon might be alot better option, even if it cost more, it would sell for alot more later.
Keep in touch Greg. The engine is the main reason I'm thinking of swapping since there's almost no chance of me selling it alone.
PostPosted: Mon May 25, 2009 8:36 pm
Will do Athal. I probably won't be talking to Laura tonight about the diff, but hopefully by tomorrow night I'll have an answer on that. I take it if you can't sell the engine, you won't be parting the rest of the car then?
Hah! Yeah, I don't know exactly what's wrong at this point, but I'm hoping to pull the head sometime next week. The oil was pretty much pure gas...
PostPosted: Mon May 25, 2009 8:38 pm
Consider my leakdown tester as an "estimate"... I sure don't trust it to do Anything more than compare one cylinder to another and point out where the air is leaking out. Craigs will tell the true tale. The engine is still worse off than your B20, though!
PostPosted: Mon May 25, 2009 10:04 pm
The engine sounds like a very good idea if you can't find a donor car. We saw a ton of clean 240's in Portland. Greg - leak down any time.
PostPosted: Tue May 26, 2009 7:10 am
It's not that I won't part the car out, but I sure ain't sending the motor to the wreckers, so it would take up a corner in my garage and sit, and sit, and sit...not the ideal situation, which is why I'm thinking finding a clean donor might be the better option if I can't sell it.
PostPosted: Wed May 27, 2009 1:13 pm
Right, so someone talk to me about the 3.54 gearing. The whole goal for the YROG is to build a car that haul's ass on the highway and track. I'm not interested in drag racing, but I certainly don't want a dog at slower speeds either. I just don't care much about performance off the line. Currently with the M46, first and second are too short anyway, so the taller gearing would be better. But then you hit third and the gap seems huge, so taller gearing would be worse there. What's your experience Athal?
Also to consider in this equation is that the M46 will be ditched at some point down the road.
Besides that concern, would I be swapping the whole axle, or just the LSD?
Laura says good to go....as long as this is a "smart decision," ie. I don't want to be doing this twice.
